Ana içeriğe geç
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
523 Soru Tümünü görüntüle
To repair or not repair. Fix it or replace it?
I need some advice/input. My 2011 MacBook Pro (A1278) has been a pet project for me and I have upgraded several parts: hard drive, RAM, keyboard, hard drive cable, dc-in, etc. Then my screen got smashed so has to be replaced. I would do it w/o hesitating but there has been an issue w/ the battery that I cannot figure out. The battery is not recognized so I can only use it while it’s plugged in. I tried everything possible on the software side. After none of that worked I replaced the battery, the charger/adapter the magsafe dc-in, the sleep sensor, and none of that worked either. I know this machine has been extended well past its years but I can’t afford to buy a new macbook right now and I need to be careful and conservative with my money. (Not to mention I dont like that I can’t open up new MBP to do simple repairs). I want to know what you all think about my options and what you would do. At this point the options I am leaning toward are (1) getting a fairly basic PC that I can immediately upgrade w/ RAM, maybe a hard drive, and (2) fixing my mbp screen and try to keep extending its age. I hesitate to do that because 1) a new screen is $300 which could help pay for a chunk of a new machine; 2) i wont know how much more i can get out of that machine and 3) needing to be connected to an outlet just sucks.
I welcome and and grateful for all advice, tips, suggestions, other points of view, and anything else you can throw at me.
Thank you so much!
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
Did you just crack the glass or did it get all the way into the LCD?
tarafından
No, it is shattered all across, all the way throuh. I need a laptop and Im trying to get one by investing some wok to save mney but having a hard time findng one.
tarafından
Yorum Ekle
Dizüstü Bilgisayar Bataryaları
An easy fix for a big power boost.
Hemen Alışveriş Yapın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
For 300$ you can buy a couple of used screens, not one. Prices for the full machine according to Bidvoy survey on ebay last week average prices are around 300$. Of course that is an average including all sorts of late 2011 Macbooks, including those for spares and/or in bad conditions, but it should give you some additional info. Fixing your board will be somewhat expensive and unless you have the i7 version I’d be a bit hesitant to recommend fixing it right now..I’d rather look for a 2012 2,5Ghz board which is upgradeble with Mojave and has a better video card. Unless your screen assembly is in very poor conditions you may also consider replacing glass and lcd panel, on pre retina machines is feasable, although a bit troublesome, but will help you save the money you’d need for a board upgrade.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Deborah Lorine sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 20
