Will it work? Swamping SSD's move from one MacPro to Another?
Can SSD’s between 2 different Macs of similar model and era be swapped? In doing so, does each function as the other did prior to the swap without any extra programming?
If so, do the serial numbers remain with the original units?
Update (03/09/2019)
Thank you so much. But, if I swap SSD’s on like machines, doesn’t the operating system also go with, rendering the need to install an OS unnecessary?
Bu iyi bir soru mu?
1 Yorum
@newtomac If you swap the drive the new one won't necessarily come with the OS already installed, it might be just formatted. However, that's no reason for concern, a new OS may be downloaded and installed with just an internet connection and few easy steps: https://support.apple.com/en-ke/HT204904
arbaman tarafından
