Ana içeriğe geç
computer showing not charging but battery shows full.
the battery shows full when i press the button on the battery but on the computer it shows that the battery is dead and is not charging.i have done all the resets that were recommended and still same problem.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Download and run Coconut Battery and tell us your results. Here's where to get it: http://www.coconut-flavour.com/coconutba...
iBook G4 12" 1.33 GHz Battery Replacement
Bu yanıt yardımcı oldu mu?
Puan 4
3 Yorum:
current battery charge: 0 mAh
maximum battery charge: 0 mAh
current battery capacity: 0 mAh
original battery capacity: 4400 mAh
battery Loadcycles: 245
age of mac: 61 months
charger connected : yes
battery is charging: no
tarafından
Well, Coconut battery shows the battery to be kaput. Time to replace it. Unless you KNOW this not to be a fact. The battery connector might also be bad.
tarafından
ok thank you i will check it out
tarafından
Yorum Ekle
Have you tried a different battery? Otherwise, it sounds like a power supply issue...
Puan 0
2 Yorum:
So even I'd the battery shows full when I push the button on the battery it could still be the battery
tarafından
Ok I bought a new battery and now that one lasted only two months and now it won't charge and seems to be dead now the computer works with the cord plugged in but won't charge the battery the cord is new because the old one stop working and wondering if it might be the dc board that has a problem
tarafından
Yorum Ekle
Yanıtını ekle
Mario sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 563
