Charging port clogged with foreign material after dropped in bucket
Charging cord will not seat in port due to obstruction. What is a good cleaning solution?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Grab a toothpick and gently clean it. A q-tip with 99% alcohol works too.
Bu yanıt yardımcı oldu mu?
Not working. The plug only inserts to the detent and will not insert further.
Is the charging port replaceable?
The port Is replaceable.
iPhone 5s Lightning Connector Replacement
I would however use a light to check the port and make sure you have removed any foreign debris.
Wow! I found a kernel of rice packed at the bottom. The owner had stuffed the phone in a bag of rice. I used angled tweezers. The alcohol softened the rice. Thanks guys! I have spent 20+ years repairing avionics components. This is starting out pretty entertaining and educational.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 626
