New battery displaying incorrect percentage & dying around 30%.
Hey all,
Just replaced my Macbook battery and the charge is lasting a fantastic amount of time! Only problem I’ve run into is an inaccurate display of charge. For instance, Coconut Battery displays it at anywhere from 95-99%, while the icon on the top bar displays 100%.
I was in the process of calibrating it after an SMC reset, but noticed that it went to sleep at around 29%. I know we’re supposed to wait at least five hours so it fully drains before charging again, so I was concerned that it wouldn’t be enough time if it was still so high.
Any advice on this? Here are specs on the battery:
System Info:
Battery Information:
Model Information:
- Serial Number: D8622873BQZDNMGAX
- Manufacturer: SMP
- Device Name: bq20z451
- Pack Lot Code: 0
- PCB Lot Code: 0
- Firmware Version: 511
- Hardware Revision: 3
- Cell Revision: 1150
Charge Information:
- Charge Remaining (mAh): 8071
- Fully Charged: No
- Charging: No
- Full Charge Capacity (mAh): 8604
- Health Information:
- Cycle Count: 2
- Condition: Normal
- Battery Installed: Yes
- Amperage (mA): -1670
- Voltage (mV): 12058
P.S.: Other small issue, Dark Mode keeps switching off and back to Light Mode after shutting down and restarting. Mildly irritating.
Bu iyi bir soru mu?
1 Yorum
You'll need to talk with the seller of the battery to get a replacement battery.
Dan tarafından
