Musty smell - santize cycle
All of our clothes are smelling musty so we want to run the sanitize cycle. How do we do that? Should we add liquid bleach?
Thanks!
Bu iyi bir soru mu?
Thanks!
Bu iyi bir soru mu?
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
Bu yanıt yardımcı oldu mu?
Check out a device called a washer fan. It's an aftermarket product that easily installs on the back air intake of your washer. It continually blows fresh air thorough your washer to help prevent smell problems
I own an older Kenmore Elite Heavy Duty Quiet Pak 11 top loading washer. It has a musky smell to it. I have used bleach in the soap despenser and it helps for a while, then the smell comes back. I do leave the lid open when it's not in use. I don't see any areas that I can take off to look for build-up that might be causing this smell. Please advise what I can do differently for this matter.
Susan
Son 24 Saat: 9
Son 7 gün: 49
Son 30 gün: 189
Her zaman: 36,834
