Ana içeriğe geç
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
260 Soru Tümünü görüntüle
Will not display after screen replacement
I replaced the screen on a 2016 MacBook Pro with touchbar, after the screen was replaced when it boots up, it will not display to the screen, however will still display to an external monitor. I can get the screen to display on the laptop when I boot to an external drive sometimes, and I have tried another screen, and I get the same result. Installing the original screen solves all these issues and it works as normal. Any suggestions?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
Have you tried an NVRAM reset? https://support.apple.com/en-us/HT204063
tarafından
I've tired, and unfortunately had no luck
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@butch00772 I would return the display as its defective! The only other possibility is you damaged it in the process of installing it.
While these displays are very expensive they are quite easy to replace. The backlight cable is very sensitive in the newer 2016 & 2017 models as the cable is a bit short so it stresses at the connection point at the T-CON board.
Review these:
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I’d see if there is a connection issue on the screen cable. The connection might be bad. In addition to this, you might be suffering from the "stage light” issues that were explored by iFixit. If that doesn’t work, try an NVRAM reset, and if it still doesn’t work, the problem is somewhere else.
Puan 0
1 Yorum:
I've checked the connection, and it appears to be fine, I tried to update the MacBook, it was running High Sierra, and after the update to Mojave it displayed with no issue until the computer rebooted, and now it's having the same issue
tarafından
Yorum Ekle
Yanıtını ekle
Butch Siragusa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,057
