Internal MagSafe port no longer connected
The internal MagSafe port is no longer connected to the logic board. Is there anyway to fix this?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
strings welcome the hardest part of this repair would be to find a replacement unless you have a donor board available. It appears to be pretty standard across most models. The connector is reference designator J7000 and is an apple part number 518S0508 The other marking are WTB-PWR-M82 M-RT-SM
WTB stands for Wire to board. You can easily check molex.com. Measure the broken connector for pin width and pitch and then match those up with some of their connectors. Of course, digikey.com and mouser.com may also have a replacement
Bu yanıt yardımcı oldu mu?
@oldturkey03 - Thanks! I wasn't able to locate it either from the parts houses.
Not good ;-{
You lifted the connector body snapping off the pins. You’ll need to find a junker system logic board to steal the connector. You might try a local Mac repair person they may have the part and can put it on for you.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 66
