What is upgradable on my iMac Intel EMC 2389?
What components are upgradeable on my iMac Intel EMC 2389 that would be worth the time and cost?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
You currently have the middle level machine, the RAM is maxed out ar 16GB
Apple iMac "Core i3" 3.2 21.5-Inch (Mid-2010) Specs
Identifiers: Mid-2010 - MC509LL/A - iMac11,2 - A1311 - 2389
Maximum MacOS:X 10.13.x*
https://everymac.com/systems/apple/imac/...
Taking it to the "Core i5" 3.6 will only give you a 15% increase in benchmark.
Your best best will be going to an SSD drive. You have a
Serial ATA (3 Gb/s) bus so you will need a drive that is backward compatible.
You will also need the OWC thermal sensor to prevent run away fan issues. Here are your options:
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 732
6 Yorum
"Worth" is subjective; what might be worthwhile for you may not be worthwhile for someone else.
In the realm of internal upgrades, if your iMac has a Core 2 Duo or Core i3 processor you can max it out to 16GB. If it has a Core i5 or i7, you can go up to 32GB.
For your hard drive, you can either install a larger capacity and/or faster hard drive, or if you really want a nice boost you can install an SSD.
If you can live without an optical drive, you can also replace it with a second internal drive (either SSD or HD).
Alternately, you can replace your optical drive with an internal blu-ray drive.
Steve tarafından
There are three different processor versions of this machine, which one do you have?
https://everymac.com/ultimate-mac-lookup...
How much RAM do you have?
What is your storage situation?
mayer tarafından
3.2 GHz Intel Core i3
16 GB 1333 MHz DDR3
Andy Walker tarafından
I have a 1TB internal hard drive(original) with 400GB free space.
Here's a listing of the possible configurations: iMac11,2
The best this series will support is a i5 3.6 GHz CPU with 16 GB of RAM.
Dan tarafından
1 tane daha yorum göster
