Ana içeriğe geç
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Soru Tümünü görüntüle
MacBook Pro won't start
My MBP won't start anymore. All I hear is the optical drive startup sound. When it started it did this a few and then it would boot but now it doesn't start at all. A couple of times that it did start I was able to log in and then it would crash/restart again.
https://youtu.be/UpG_9SUOA7E
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
What does the MagSafe LED show you Amber or Green?
tarafından
Green, it works fine. It has been doing this for a while now but this time it's not even starting up no matter how long I leave it running. The few times it did boot up I was able to log in but then it restarted again.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Let’s go for a spontaneous reboot. Unplug the mag-safe, disconnect the battery from the logic board, press and hold the power button for 10 seconds. Reconnect the battery then the mag-safe. Let us know if it boots.
Bu yanıt yardımcı oldu mu?
Puan 4
7 Yorum:
Still the same. Someone suggested it might be a HD problem. The internal HD is actually dead and I've been using an external HD to boot from buy the internal drive is still in there. Do you think this could be causing the issue. Should I attempt to remove it?
Edit: I removed it and nothing changed
tarafından
Push the battery test items on the side and see how many lights it shows.
tarafından
100% even though the battery is not in a good shape. I don't think it's related to power at all as it turns on. The fans are running when this noise is happening. It's trying to start up
tarafından
Are the LED's blinking?
tarafından
I think it's an overheating issue as it started up in the morning. I'm afraid to out it to sleep or restart though.
tarafından
2 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Joe G sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 354
