My Whirlpool Refrig ED2JHETS00 can't start 2nd cooling cycle by itself
By turning temperature setting knob back/forward from its “OFF” position to different cooling temperature positions a couple of times, the thermostat will trig on compressor working till 4C temperature setting point. After that, this refrig will not trig on by itself when temperature inside raises. When I start over to play same temperature setting knob again, it will work again at same pattern. Does this indicate the thermostat (temperature setting knob) fails and needs a replacement?
Bu iyi bir soru mu?
Is it possible that "Start Relay" is bad and needs a replacement?
Su Zhang tarafından
