Ana içeriğe geç
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
iPad won't charge reliably; Lightning connector bent
I’m fairly sure the Lightning connector on my iPad Mini 2 bent when it fell off the bed while charging. I can charge it if I pull up on the cable (toward the screen), but then it stops charging when I let go.
What’s the best way to remedy this? I think if I could get to the connector, I might be able to bend it back into shape, but I don’t know if that’s possible without removing the entire logic board. Does anyone have an idea of how to fix this issue?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
You will have to replace your charging port. For the meantime if you want to bend it back into shape use a non static tool like a Spudger and when you do that make sure your iPad is off.
A tougher take on a favorite multitool. Safely poke and pry with this tough, firm, and antistatic tool for electronic repair. 5” carbon fiber tool essential for smartphone or tablet disassembly. Görseli
Ürün
Spudger
$3.99
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
You can replace the charging port on this device? I thought that it was soldered to the motherboard.
tarafından
Yes you wont be able t do it by yourself.
Where you able to bend it back into shape?
tarafından
Yorum Ekle
Yanıtını ekle
Calion sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 428
