Ana içeriğe geç
Also sold under the GMC Sierra and VIA Vtrux names, available in the US, Canada, Mexico and other countries around the world.
77 Soru Tümünü görüntüle
Can I disable the security system so my truck Will stay running
I tore out my ignition to crank it with a screw driver, I did it 6 months ago, Now my truck starts then shut off because of the security system, how can I disable it????
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
My fiance said to wire the middle wire and the one closest to the driver door together, use the screwdriver as the key and go through a process of rebooting the security which is 3 sets of 10 second and 10 minute intervals. So you turn the key to the on position then crank it over, release the key so the ignition stays in the on position and allow the vehicle to sit for 10 minutes. After the 10 minute period go back to the truck and turn the key to the off position for 10 second, crank the truck over and then leave the key in the on position again to start round 2 of the intervals. You will do this a total of 3 times, after the 3rd time the truck should start up. Good luck!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
You can likely find a fuse to pull for your security system, but if it is factory, you will most likely disable power locks as well.
I’d look at your fuse box and see what you might find there.
Puan 0
Yorum Ekle
Yanıtını ekle
Dustin Locklear sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 78
