Cut electrical wire cord for A1243
I need to know how to replace the cable or repair it.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If it is an USB cable that was cut then you should open your keyboard and re-solder a new cable to the PCB. Please mind to properly connect polarity of the USB power supply and Data cables. It will be 4 wires + ground so if you are handy with soldering iron then you should handle with it.
Bu yanıt yardımcı oldu mu?
then finish your %#*@ teardown and fix it while your doing it
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 1,180
