Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3531 Soru Tümünü görüntüle
5s and se the same
I have a iPhone se in poor condition with a broken screen. I also have a 5s in perfect condition that is iCloud locked.
What are my options to get one good phone. Can I transfer screen from 5s to the se, are they the same.
what do I need to take from se to put in 5s to stop iCloud lock, the logic board and home button?
Update (04/23/2019)
What about getting past the icloud lock on the 5s, anyway round it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Iphone 5S is iCloud locked so you can not use its logic board or any part which is associated with imei number. You can use battery, body cover if size are same and display. But for Display make sure screw position alignment are same for both screen otherwise it will not work. Better to use both iPhone use iPhone carrier unlock code for iPhone 5s.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Actually no, the battery is different between the SE and 5S, the only thing you can really use is the screen as they have the same connector. The battery and charging port have different connectors. Hope this helps.
tarafından
Yorum Ekle
If the 5S is locked and you want to restore the SE the one thing you CAN do is use the 5S’s screen on it. But the battery and charging port are different between the two models, if it’s just the screen your mainly looking for then your in luck. If it’s anything else major I don’t think anything else will work, that’s just from my experience, hope that helps.
Puan 0
Yorum Ekle
If the screen is OEM, it will be pretty much fully compatible with the SE.
Puan 0
Yorum Ekle
Yanıtını ekle
Aidan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 79
