Ana içeriğe geç
Soru Kapandı
Why does my new Hard Drive cause system shutdown
I have an early 2006 A1150, with 2 GB of RAM.
I had just installed a new HDD (http://www.newegg.com/Product/Product.as...) which is a Seagate 7200 RPM 500 GB drive. Which I've researched others successfully installing into their laptops.
Now the box will shutdown after an intermittent amount of time. I gain the most of the time, when the box has been turned off over night and is stone cold.
Does anyone know what the problem is, am I drawing too much power?
Is it too much heat?
Is the extra power causing something else to overheat?
Does the Logic board not support 7200 RPM or some other protocol? (S.M.A.R.T/ Sata 3 / etc. )?
Is some kind of firmware required?
Should I get a different brand (Western Digital) or different speed (5400 vs 7200)
I was running the latest patched version of SL w/Vista SP2 via BootCamp. I didn't have any problem installing the OS, it just seems like this started happening in the last week or so.
If you want the full story click over here.(http://www.ifixit.com/Discuss/thread/969...)
Thanks for any ideas or help. I will keep everyone posted on my travails.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
From what I've been reading there seems to be a problem with 7200 rpm drives in laptops. Problems seem to be noise and heat. Checking Mactracker for your computer it would seem the best choice would be a 5400 rpm drive. A good check if you still have the drive you removed would be to reinstall it and see if the problem goes away. Hope this is of some help. Ralph
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
rj713 i was thinking of replacing my drive with a 7200 rpm drive, can u please forward any links with these discussions before i jump blindly into this upgrade? thanx
tarafından
http://www.macnn.com/articles/09/07/09/m...
Hi majesty--try this as a start. Ralph
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,637
