Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
1695 Soru Tümünü görüntüle
PS4 Model CUH-1216B only has 2 screws, how do I open it
Hello, my PS4 Model CUH-1216B only has 2 screws on the back. Can you please explain how to open it. Since a few days it won’t start up again. Starting it, I only get a screen saying “connect the dualshock 4 with a USB-cable and next press the PS-key”, which doesn’t do anything. I got it once in safe mode and tried to reinstall everything, but then it crashed again and now I am stuck! Does anyone has an idea about what could be causing this? Thanks for your support.
Bob
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If you have already exhausted all the options in safe mode with the full PS4 initialization firmware file downloaded into the USB then it’s going to be a bad hard drive.
Software update can fail with error code if the blu-ray drive is not working. As long as you can eject and insert discs into the PS4 the blu-ray drive should still be good.
PlayStation 4 Hard Drive Replacement
PlayStation 4 SAA-001/SAB-001 Hard Drive and Bracket
PlayStation 4 SAA-001/SAB-001 Hard Drive and Bracket Görseli
Ürün
$29.99
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Press and hold the power button until you hear two beeps: one when you first press and another seven seconds later.
Puan 0
1 Yorum:
i can't click on the other options except for number 7 , what should i do ?
tarafından
Yorum Ekle
Yanıtını ekle
Bisshop Jyr sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 1,443
