Screen is damaged internally
Screen doesn’t show physical damage only internal.. How can I fix this?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
As you can see, in the upper right corner of the screen there is a crack (circled in red) in the liquid crystal layer of the screen, which is most likely causing the horizontal lines going through the LCD. I would send the the laptop to a repair shop for them to fix it for you because the Surface Laptop is very, very difficult (or maybe even impossible!) to open up with out inflicting lots of damage to both the internal components and outer casing.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 1,292
