Water Damage Repaired, Later Doesn't Charge
It’s been about a year and a half since liquid was spilled on the keyboard and it no longer powered on. It was repaired by a reputable shop but after leaving the laptop for a few weeks recently, the battery is at 0 mAh, the magsafe lights up orange, but battery is “not charging”
Did all the SMC resets and stuff, which actually for whatever reason is what made it start showing the orange light instead of green. The battery was replaced at time of repair.
My question is, charging circuit, a fuse? What is likely the issue, as I’ve only repaired iPhones. I can just sell it and let it be someone else’s problem, or if its not too hard to trace and re-flow or jump maybe I can do it.
Bu iyi bir soru mu?
3 Yorum
How about installing this gem of an app so we can see what's happening CoconutBattery. Take a snapshot of the main window and post it here once with the MagSafe connected and once disabled. Adding images to an existing question
Dan tarafından
Added a couple of pictures, it was saying 0% plugged in, not charging. Now it says 100% but shuts off instantly when adapter is removed.
keenor tarafından
@keenor what did the repair that was made consists off? Post some good pictures of your logic board with your question. Let's see what we can find out. I don't think a fuse is at fault here but a sensing resistor is a possibility
oldturkey03 tarafından
