Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
339 Soru Tümünü görüntüle
Can I add discrete graphics to Mid 2014 MacBook Pro
Hi I have a retina macbook Mid 2014 with intel Iris graphics and wondered if I could add discrete graphics to it as an upgrade?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
There’s no way to do that.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
This series came in two different configurations:
Intergrated Graphics
Dedicated Graphics
The logic boards are physically different! You can't add the GPU chip. You can only swap out the logic board which would be expensive!
tarafından
Thanks Dan - that answers my question
tarafından
Yorum Ekle
If it was the 2016 or newer model with Thunderbolt 3 ports, I would have advised you to research the possibility of using an eGPU. I don't believe this is available for the model you have.
Puan 0
Yorumlar:
There are a few eGPU systems which work via Thunderbolt-2. At this point it would be a used unit.
tarafından
Yorum Ekle
Yanıtını ekle
Jeffers De Maio sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 123
