Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1172 Soru Tümünü görüntüle
Stripped 1.1mm screw above home button.
Hi all, I’m really hoping someone will be able to give me a hand here, so the 1.1mm screw on top of the home button of my iPhone 7 plus is stripped, and absolutely refuses to get out. I have tried the superglue technique (superglue the driver to the screw) and am worried it may have even glued the screw to the bracket. The only solution I can think of is to bend the home button bracket on either side of the middle screw, and use the bracket itself to remove the screw from the home button. I have ordered a new home button bracket either way, does anybody have any other ideas? Should I even attempt what I am proposing?
Thanks in Advance.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
Easiest solution as Chris suggested is carefully bend the bracket on both sides upwards push the hole thing through the hole then just straighten it and screw it into the new screen
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You could try and set the phone in the fridge for 10 minutes or so to allow the metal screw and bracket to contract a little bit which might help loosen it. Then maybe the super glue trick might work, hopefully you haven’t glued the screw in place, just a thought
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
I'll give that a go, thanks.
tarafından
Don't do the whole phone do the screen only.
Don't want to cause condensation on the whole phone. Also make sure to remove the front camera assembly before putting the screen in.
tarafından
Yorum Ekle
ive had this before, managed to bend the bottom of the bracket up 90deg and get the button out the screen and back into new screen successfully without having to remove the screw. risky but doable.
Puan 0
Yorum Ekle
Yanıtını ekle
llamalulu42 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 174
