Ana içeriğe geç
22 Eylül 2017'de satışa sunuldu. Model A1863, A1905 olarak tanımlanıyor. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Altın, Gümüş, ve Uzay Grisi renklerinde satılır.
869 Soru Tümünü görüntüle
iPhone 8 in infinite bootloop tried everything and EVERYTHING
So after i updated my iphone 8 to ios 12.2, my phone started going on an infinite bootloop i tried everything dfu mode recovery mode no avail. sometimes when it comes off battery I can actually get it to the start screen and even set it up, but when it loses battery/ shuts off its bootloop again. I even removed battery and plugged it in with charger and it still bootlooped. I dont understand the problem AHHHH
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
ALSO when it does get to the start/hello screen the haptic feedback doesnt work
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Could be just a bad battery. Try getting that replaced and see how that goes.
iPhone will just flash apple logo on and off with battery disconnected so it needs a working battery for the iPhone to turn on.
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
really? How come the phone works when I do my little trick thingy until it gets powered on again. During this time the battery works just fine.
tarafından
all though after the update it was working fine until it randomly shut off
tarafından
If the phone works fine when the battery is charged but does not when it drops to a certain percentage that points to a bad battery.
tarafından
The phone works with all percentages battery doesn’t seem to be a problem
tarafından
Yorum Ekle
Get New Battery. that’s your problem
Puan 0
6 Yorum:
but it works fine when I get it to homescreen zzz
tarafından
Ah ok. Did you change the screen?
-- test audio also. Can you put the phone on speaker during phone call?
tarafından
No I can’t put the phone on speaker during a call
tarafından
If the speaker phone is greyed out during calls and voice memos record shows no recording device found then the phone has an audio IC problem.
To get that fixed the phone will have to be taken to a reputable phone repair shop that does micro-soldering.
tarafından
this is what is causing the bootloop?
tarafından
1 tane daha yorum göster
Yorum Ekle
If you haven’t already fixed this, I have found that disconnecting the front proximity sensor altogether works, however, you lose the selfie camera feature…..
Puan 0
Yorum Ekle
Yanıtını ekle
Levy Nguyen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 144
