Ana içeriğe geç
HP Laptops designed for home and home office use.
667 Soru Tümünü görüntüle
HP pavilion x360 15 CroXXX phantom ethernet connection
My laptop doesn’t even have an ethernet port and its showing an ethernet connection. It has been causing problems so I need this gone. Anyone have this issue before and know how to fix it?
Update (05/16/2019)
Here are the devices that show in device manager
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
Hi @connor2003
How are you?
some things you can try.....
updating the computer BIOS,
what do you see in device manager on network adapters?
tarafından
I posted an update, please check it out.
tarafından
are you able to uninstall the Realtek usb gbe family controller from device manager?
if you are not using it, consider removing the drivers by checking it when you remove the device from device manager.
tarafından
@connor2003 all of it looks like wireless connections, not ethernet. What model is your computer?
tarafından
Hp x360 convertible 15-cr0037wm
tarafından
Yorum Ekle
Dizüstü Bilgisayar Bataryaları
An easy fix for a big power boost.
Hemen Alışveriş Yapın
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I see a VPN device driver installed. Uninstalling the vpn software should fix the problem.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
Disabling it is the farthest I can go (still didn't fix it) Removing it would require entirely reinstall my vpn software.
tarafından
You can go into control panel then go network and sharing Center then go to network adapter's and see what it's called when you right click the ethernet adapter and go into properties
tarafından
Yorum Ekle
was this always a problem or is this something recent if so i would try using recovery setting to go back to a restore point if you are using windows 10 use the search bar and type recovery then open system restore follow the prompts and choose a date and time as far back as you can this should reset the setting back this will not effect your files
Puan 0
Yorum Ekle
Yanıtını ekle
Connor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 8
Her zaman: 71
