Ana içeriğe geç
A programmable brewing machine by Keurig. This coffee maker uses K-Cup Pods and K-Carafe Pods to brew a variety of hot and cold drinks. Model Number: K2.0-400 Serial Number: 401.0200.1410931
60 Soru Tümünü görüntüle
Why do I keep getting coffee grounds when it brews?
why do the pods keep leaking grounds when brerwing
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
May need to clean and descale
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
lheureuxnorm  take a look at the puncture needle areas and make sure that bottom one is not clogged. That would cause all the pressure from the K-cup to go to the top. Step 2 on this guide although slightly different model, should help you with that.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
It could be a couple of things.  The top needle could be dull after many usages and it is pushing down the pod before the needle penetrates the top seal which causes the bottom needle to go too far in the bottom  and  cut into the built in filter in the cup.  Also it could be  defective pods. If you use recycle pods this over time will dull your needle. Hope this helps.
Puan 0
Yorum Ekle
Yanıtını ekle
lheureuxnorm sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 33
Son 30 gün: 120
Her zaman: 4,591
