Where can I get a ribbon lock for the screen ribbon?
I busted the little black plastic ribbon lock that keeps the screen ribbon in place whilst trying to re-attach it. Is there a good source where I might be able to get more?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I think you're talking about one of these (the black part): https://d3nevzfk7ii3be.cloudfront.net/ig...
If that is indeed what you're talking about, it's not a separate part. It's part of the socket that the ribbon cable fits into. Best case scenario is you only broke the black plastic piece and the rest of the socket is intact, in which case you can try to find the same socket elsewhere, pull the black plastic piece off, and push it into place on your iPod. If the socket itself is damaged, however, the proper repair is to replace the whole socket.
Otherwise, look for ways to rig a fix. Put some kapton tape on one side of the cable to provide pressure, slide/press it into place, then some more tape to hold it in place and hope it doesn't come loose.
Bu yanıt yardımcı oldu mu?
Thanks! That's the part, except it's the one on the logic board itself. Are you talking about Kapton tape?
Nevermind! I just saw the link to the tape
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 78
