Ana içeriğe geç
A clothing iron, also called a flatiron, is a heated surface used to remove wrinkles from fabric.
85 Soru Tümünü görüntüle
Does someone know how to disassemble Philips PerfectCare GC9220 iron
Hello,
Does anyone know how to disassemble part 17 on page 4 of the service manual ?
https://www.manualslib.com/manual/953960...
One of the switches is not working anymore and I’d like to fix it.
thanks!
Benn
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @benoitmagicien
Well I guess
Most probably you need to get this
iFixit Opening Tool
The plastic seems to be clipped
take note on the red catch of the plastic when your remove
iFixit Opening Tool Görseli
Ürün
iFixit Opening Tool
Bu yanıt yardımcı oldu mu?
Puan 1
7 Yorum:
Hi,
Thanks for your input, actually, the red catch I can get out easily, the whole back part is also not attached, so those things are not plastic catches.
Basically, i can lift the front and the back, but it's blocked by something (probably plastic catches) around the whole in the middle. And I can't get to the screws you circles without removing part 17 first...
tarafından
Hi @benoitmagicien
work slowly, if you have a opener, that's great, else if have a used credit card, can slot in and try removing it, but slow and steady.
If you feel there are a lot of resistance or suspect there is a screw, slow down or stop.
tarafından
There is a lot of resistance, but there is no screw to access.
Here's what it looks like from the top :
https://images-eu.ssl-images-amazon.com/...
tarafından
able to take out 18 and part 13 first?
tarafından
That seems like a very very good idea !!
I'll try that first thing when I get home and keep you posted !
Thanks !!!!
tarafından
2 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Benoît DESTRUBÉ sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 1,301
