Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2039 Soru Tümünü görüntüle
Unable to Activate Shutdown message (BB_CPU?)
Hi,
I have accumulated quite a few iphones 7/7+ which i could not start due to message Unable to Activate Shutdown. Initially I thought it could be BB_CPU problem but usually it happens after attempted Audio IC job and the phone still boot but does not show IMEI/Modem Firmware. In that case I just re-ball BB_CPU.
But the phones at hand with this error message have not been opened before so I am confused. perhaps more experienced micro solderers could shed some light? Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This sounds like a Qualcomm model. The baseband power management chip has a voltage regulator inside. I think it becomes shorted sending VDD_main voltage into the baseband chip that is why apple had a recall on that model. You could replace the baseband power management chip but the damage has already been done to the baseband ic.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
It is actually Intel version. But nevertheless it is interesting theory. You might be right that at some point BB_PMIC was sending the VDD_MAIN voltage to BB_CPU and damaged it. So even if you replace the BB_PMIC the damage has been done to BB_CPU already.
I tried to re-ball BB_CPU but I am getting the same message/error. That supports your theory. I guess those devices go to 'No Fix' box.
tarafından
If it’s an Intel version I would take some diode readings around the BB_PMIC I would not declare it a no fix until you are sure it is not just the BB_PMIC which are easily replaceable
tarafından
Yorum Ekle
Yanıtını ekle
Karolis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 239
