Ana içeriğe geç
The fourth-generation Hyundai Elantra was released in 2006 for the 2007 model year. The Hyundai Elantra sold under the name Hyundai Avante in its South Korean home market.
14 Soru Tümünü görüntüle
Horn blows intermittently with vehicle parked and off.
The horn on my 2010 Hyundai Elantra GLS goes off intermittently when parked and not running. It always blows 18 times, stops for about 5 seconds, then blows another 18 times. I can push the lock or unlock button on the key fob and it will stop, but will start again on it's own, for no obvious reasons. I changed the batteries in the key fob but that didn’t help. The TPMS light is also on solid, but I think that is a different problem as the light was not on when this issue started. I can pull the horn fuse and of course it will not go off. Any ideas would be appreciated.
Thanks!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Use your key (not the fob) to lock then unlock the driver side door to turn off your security alarm.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Mine did the same thing when I disconnected the positive(I believe) terminal from battery. After some research what I gathered was there used to be a remote start installed and it’s just the remnants of it or something. I tapped the brake and it stopped.
Puan 0
Yorum Ekle
Thanks for the reply. Finally went to the dealer who removed an additional anti-theft system the previous owner had installed which was not playing nicely with Mazda's built in system and it's fine now.
Puan 0
Yorum Ekle
Yanıtını ekle
veteransnewstoday sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 43
Her zaman: 6,476
