Ana içeriğe geç
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
20 Soru Tümünü görüntüle
Recommendation for an adhesive that doesn't instantly bond?
I am planning on mounting a new 13” LCD panel on a Mid 2014 MBP.
From what I’ve read and seen, you must execute several steps in exact order. If you skip any of them inadvertently, or misalign the panel, you must correct the problem by unmounting the panel. This is the only part of the procedure that terrifies me most as it poses a high risk of cracking an expensive panel.
Are there any double-sided tapes or adhesives available for mounting the LCD which doesn’t instantly form a high strength bond, giving you the ability to align or remove the LCD more easily, if needed?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
When I do replace the cover glass panel on the older Unibody’s I use Tesa 61395 Tape As long as you don’t press it down firmly you can still shift the glass if needed. Then, once in place I put a 5 lb weight which presses evenly across the entire surface via a cut piece of plywood covered with felt.
Custom cut rolls of Tesa 61395 double-sided tape for repair. Görseli
Ürün
Tesa 61395 Tape
$5.99
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
I hope you are not thinking about working on the guts of a Retina display.
Here’s how to replace the display assembly:
MacBook Pro 13" Retina Display Mid 2014 Display Assembly Replacement
Puan 2
5 Yorum:
I know how to replace the assembly, but I am asking specifically about the adhesive for boding the LCD panel.
tarafından
Review this: MacBook Pro Retina Display Teardown
I really don't recommend taking the panel apart!
tarafından
I don't either, but what would you do with a perfectly good LCD panel with a housing in bad condition? Luckily, I removed the lcd without issue, but putting it back on is tricky, since I often skip steps or do them incorrectly.
tarafından
What I do is slap a hard cover on it: https://www.amazon.com/s?k=macbook+pro+1...
tarafından
@mayer It's an acceptable solution for a machine for personal use, but for refurbishing for resale, it is less than ideal. Anyway, I have successfully refurbed a dozen of these displays and they're tricky and terrifying at first, but if you're very careful and methodical, it is doable.
tarafından
Yorum Ekle
Yanıtını ekle
AppleGuyPie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 89
