Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
1763 Soru Tümünü görüntüle
Proximity Sensor not working after repair
Hi. I have recently replaced an iPhone 7 Screen. After a few days, the proximity sensor has stopped working, so when on a call, the other person can hear my cheek pressing buttons. Any ideas?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
TÜM SEKMELERİ AÇ
Mac için RAM Yükseltme Kit'leri
Kit Satın Al
Tüm Sekmeler İçin Yeterli RAM
Kit Satın Al
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
There are a number of reasons why this can happen:
  • The sensor is not properly aligned. Tear down and reassembly may help fix this. Make sure the plastic bracket is properly positioned like in the original;
  • The sensor cable or sensor solder joints were damaged during the transfer and now the whole front camera cable assembly needs to be replaced;
  • The cable needs reseating into the connector on the board;
  • The screen itself is somewhat defective and allowing too much light through. Specially for the black screens. Transfer the small white filter or try coloring a little bit the opening where the sensor sits behind the screen.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
The tear down some what helped, along with the light issue. When transferring the old sensor cables off of the smashed screen, I never transferred the light filter, or the clear plastic gasket that was holding part of the sensor in place. I was unable to transfer the white filter over as when trying to peel this away, the filter scratched away. I have found a white sticky label at home that I have put in its place, in the hope that this would have worked, and so far, there have been no issues with this.
Thank you for your help!
tarafından
Yorum Ekle
Try to take it back apart and check connecting to logic board, If that checks out replace Proximity Sensor, Very common part to break durning repair.
Puan 0
Yorum Ekle
Yanıtını ekle
Kyle Webb sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 48
