MBP boots with press on any key? Can't do SMC.
Is this normal? This way it seems I can’t do an SMC, because any press on a key will start up the MacBook Pro. How do I do an SMC on this MacBook Pro?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Wherever you are in the world you should just head to Applecare, either online or in a local store. What you are experiencing is not normal at all and will most probably lead to a Mac replacement.
Bu yanıt yardımcı oldu mu?
This is normal. The Mac is designed to auto start when you press any key.
Just hold down Shift+Option+Control when the laptop is off for 7 seconds. It will turn on. After 7 seconds keep holding the keys down and additionally press the power button (Touch ID). The laptop will turn off. Wait a few seconds then turn it on normally, and your SMC should be reset!
Son 24 Saat: 8
Son 7 gün: 30
Son 30 gün: 103
Her zaman: 10,435
