Can this wire be replaced?
we were replacing the Antenna Flex Cable w/ iFixit kit. The snap end of this wire broke off. Is there a way to replace this wire, or fix it so that it snaps back in place? Thank you.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The cable comes soldered to a replacement charging port. Order another one of these and you will be fine.
Bu yanıt yardımcı oldu mu?
Good Afternoon,
I would say you need to order another cable. You could try to solder the connector back to the ribbon if you have the ability to micro-solder. Otherwise I would go ahead and order a replacement and give it another go.
Cheers!!
Monte
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 36
