Does this mean replace keyboard? Power on/off button not working.
This MacbookPro will not start with the on/off key (on keyboard). I can remove the back cover and toggle the logic board start pads and it will start. Does this mean a full keyboard replacement or is there perhaps something else I may check? TIA
Bu iyi bir soru mu?
3 Yorum
was anything spilled on it? How does the keyboard function after you get it booted up?
mayer tarafından
Daughter claims no liquid, but how does one really know? Rest of the keypad works fine, but the power button will not turn on or turn off the MBP. Is there a mechanism/circuit other than the keypad that may be at fault here? What can I check? TIA
bonesteel tarafından
You could check if the water indicators a red and check the connectors. The water indicators should be on the motherboard and under the motherboard. You could test the ribbon cable to see if its really that. (It could be the connector)
Lucas Michels tarafından
