Ana içeriğe geç
Repair guides and support for a wide range of small engines.
103 Soru Tümünü görüntüle
What steps do I take to remove water from my engine?
I know I had water in the gas tank. I cleaned the tank and filled with fresh fuel now the engine will run and then stop.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
daveystoddard  replace the plugs. Remove the float bowl from the carb and clean that and the needle valve. After that keep on running it, If it stalls try again. You can always squirt a bit of fuel into the carb to keep it running. There is not a lot of water left after you cleaned the carb etc. The rest of the water should burn off pretty quickly.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
daveystoddard sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 52
