Yes, its often done. That ball-joint is a PITA.
I picked up the special tool to separate the ball joint and it make life much much easier. Droop the rear suspension, undo the top nut, slide tool over, tighten until it pops off. Makes it a 30 minute job.
Miller 8278 - check E-bay. Since its a Miller tool, expect $100+
If you remove the entire A-arm, be careful tightening it back up. If you get a twist in the bushings along the side of the jeep, they will only last a few hundred miles and then you have to do the job again (guess how I know….) When you torque the bolts, the bushings tend to twist and this pre-loads the rubber etc.
BTW, A-arms are pretty cheap, consider buying a new one. Amazon has deals on complete suspension sets - all the control arms + a-arm etc.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
