CDMA vs GSM replacement back cover
Whats the difference between a CDMA iPhone and a GSM iPhone back cover? Why is a GSM replacement cover not compatible with the CDMA? Do you thinks its possible to make it compatible by removing some of the mounting clips or something else?
Bu iyi bir soru mu?
1 Yorum
To my knowledge they should both be compatible with each other? The only differences in the models are small hardware changes (logic board) and a different roaming frequency. Have you tried a GSM back cover on a CDMA iPhone or vice versa?
martin tarafından
