Ana içeriğe geç
The Nextbook NX008HD8G is an 8'' Android tablet released in September 2013.
20 Soru Tümünü görüntüle
Charged for a hour and screen stays black when turned on.
So it has been about a year since I turned it on and it was charging for about more than a hour and I pressed the on button for more than 5 sec. And the screen just is black.? What do I do it won't turn on?
Bu iyi bir soru mu?
Puan 0
3 Yorum
Plz help quick
tarafından
Hi @elizabeth11 ,
Did the tablet show that it was fully charged?
Does it turn on OK if you leave the charger connected and switched on?
tarafından
It does not show that it was fully charged it kinda shows like a gliched black screen
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
With the charger connected try a hard reset to see if you can get to the recovery menu.
Be aware that if this works it will erase all your data and downloaded apps and restore the tablet to its’ factory default condition.
Ensure the device is off and then press and hold the Volume Up button and then press the Power button, hold both on together for 5-7 seconds and then release the Power button only. When you get the Android recovery menu on the screen, release the Volume Up button and scroll down using the volume buttons to wipe data and then press the Power button to commence the action.
Be patient, it takes a while to perform the reset.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I don't want to do that cuz I want all 5he data to stay tho
tarafından
Hi @elizabeth11 ,
Just start the procedure to see if the recovery menu screen turns on.
You don't have to do the reset if it does.
Usually there is an option to just reboot the device.
If it doesn't even get into the recovery screen menus then there are more problems.
tarafından
Yorum Ekle
Yanıtını ekle
Elizabeth sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 172
