System not responding, Battery is good
I’m struggling with the same stuff. Trying to get alive the MBP (MacBookPro5,1) of my daughter.
Next to all recommendations, I tried the hint from here <http://www.insidemylaptop.com/turn-on-ma...>, shorting the power-on pads. No way.
UPDATE:
The model is MacBook Pro "Core 2 Duo" 2.4 15" (Unibody) 2.4 GHz Core 2 Duo (P8600)
Intro.October 14, 2008Disc.June 8, 2009
OrderMB470LL/AModelA1286 (EMC 2255)Family
Late 2008, IDMacBookPro5,1 RAM 2 GB VRAM 256 MB* Storage 250 GB HDD
Optical 8X DL "SuperDrive"
Bu iyi bir soru mu?
7 Yorum
What is the color of the MagSafe LED? Amber or Green?
What does the battery checker show?
Did you try a fresh battery?
Dan tarafından
1. Amber
2. 1st dot flashing green
3. this is a more or less new 3rd-party replacement, my daughter bought last year. Before I was trying the old from Apple again. MagSafe was green, checker with all dots green.
It would hardly reach my daughters need, to run the MBP without battery. So my main question is, how to get it start again.
I just found an eBay-offer. A MBP, immediately shutting down after taking off the MagSafe - but running properly with. Will this get the same probs after a while, or should I buy to build one running machine?
PS: Sorry for my late reply - I thought I would get noticed on comments.
Jochen Buthe tarafından
I'm a bit confused in your listing...
The current battery is Amber MagSafe and one battery checker LED lit. If that's so, you likely need another battery.
If the second battery is showing a Green MagSafe and all of the battery checker LED's are lit that is a workable battery!
I can't answer your eBay offer. Buying another exact system won't change the battery issue you have here.
Dan tarafından
Sorry for confusing you, Dan.
The battery I mentioned first is loading (that's Amber, no?) and meanwhile has 3 green spots with the checker.
Maybe the old Apple battery is working - but only for some seconds. That's why my daughter bought a new one.
Nevertheless. The Book does not start.
Now the "new" battery is loaded completely. MagSafe with green light. Checker all dots green. But still no way to start the machine.
2 tane daha yorum göster
