Change stand for a vesa mount
It can be change the regular stand for a vesa mount without cutting the stand?
Like dismounting the stand
Bu iyi bir soru mu?
Bu iyi bir soru mu?
There are a few ways to do this!
Hinge assembly
Bu yanıt yardımcı oldu mu?
Is there a guide to do this?
The other is opening your system to gain access to the hinge assembly internally and replace it and the other parts with the needed VESA mount versions. This is a lot of work as you need to completely disassemble the system
Cheers
@hugolz - You need to remove the logic board following this guide iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement Then review the picture above to remove the stand and then the hinge.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 216
1 Yorum
Cutting the stand off won't get you a VESA mount! All you'll get is a system with no means to mount it to stand it up.
Dan tarafından
