Ana içeriğe geç
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Soru Tümünü görüntüle
Can I swap the screen from a 2015 MBA to a 2011 MBA?
I have a dead logic board MBA 2015 and a damaged lcd panel MBA 2011 (has a wide vertical line on the middle of screen and flickers if you move the top lid). So I was wondering if I can swap the full display assembly from the 2015 to the 2011.
Or If I can salvage the LCD panel from the 2015 and swap with it the one thats broken in the 2011 MBA (keeping all the same connectors, antennas, iSight.. just replacing the LCD)
Thanks!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You can swap the display assembly if you’re ready to forget about your webcam, that doesn’t match by at all. You can remove and replace the panel if you wish so, they’re just the same, but it’s not an easy job, if you didn’t do it before there are pretty good chances you may end up damaging the Lcd and/or the backlight sheets.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Alejandro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 26
