Ana içeriğe geç
Xiaomi Mi A2 (küresel çapta Mi 6X olarak da bilinir), Xiaomi tarafından Temmuz 2018'de çeşitli dahili hafıza yapılandırmalarıyla piyasaya sürülmüştür. Cihaz, iki yıl boyunca güncelleme garantisi veren Android One programının bir parçasıdır.
Touchscreen doesn't work, after waterdamage
Hello,
my Phone’s touchscreen stopped working after I dropped it into a lake. I allready have put it into rice with an open backpanel. Sadly I couldn’t turn it off completely after the accident, it kept restarting repeatedly… After it stopped that it was in the usual state in which I would need to insert my Pin, additionally the Powerbutton doesn’t work as good as before.
Now is my question if I need to replace the screen or if there’s some other step I should try beforehand.
Thanks in advance :)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hello Mi A2 mobile display inside water how to slove plz tell
Update (01/10/2023)
Hello Mi A2 water inside mobile plz tell how to fix
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Since you phone seemingly survived severe water damage I’m surprised it’s even turning on right now.
Steps to take are:
  1. opening it up
  2. checking if the battery has bubbled up
  3. if so remove it carefully!
  4. dispose it the intended way (be careful it can be prone to “explode” / secure it into something that is fire resistant upon disposal)
  5. removing every little part from you phone
  6. drying the !&&* out of it
  7. checking every little contact for corrosion (especially the circuit boards)
  8. put everything back together and replace the broken screen on your way out
In my opinion it would be easier to just buy a new one - these things go for cheap on eBay and are easily repairable.
I can’t stress the danger of a shorted battery enough - if it’s getting bigger as you’re handling it throw it the f*** away from you, ideally somewhere where nothing else can catch on and start a fire.
Puan 0
Yorum Ekle
Yanıtını ekle
Laurin Kruse-Ziegler sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 732
