Need to bypass BIOS password.
I have a Toshiba Satellite C675-s7322 That I bought at an estate auction, and there is a BIOS password? I have tried everything I can think of to bypass it. Any ideas?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
There is no way to get past the Win7 password into an account.
It is possible to get into a WIN7 computer and make a new account.
try:
on Windows 7 , use F2 on cold start to go to “bootup options”, select
-Safe Boot with DOS command window, then in
the DOS window that should appear, type in
Net user administrator /active:yes {Enter}
then restart the computer, you should now see the hidden
account “administrator” login icon which does NOT need a
password, just click to enter . It is an Administrator level
account which will allow you to CREATE A NEW
Windows USER ACCOUNT of new naming, via Control
Panel / User Accounts / Create Account. If you set it
for Password access, be sure to write down the password somewhere !
BE SURE to give the new account full administrator privileges/access.
I usually make two new full Administrator Access Level accounts,
both password protected.
Exit and restart ; check to make sure you can actually
sign in to your new account(s) . (login to one, then use “Switch User”)
Open a DOS window , type in
Net user administrator /active:no {Enter}
Restart computer; your “invisible” administrator account
login icon should now have disappeared again !
BUT don’t try getting rid of an existing account that you
do not have the password for it, Windows
will want the account password in order to do that .
Shhh, don’t tell anyone !
grumpylumpy
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 444
