Ana içeriğe geç
Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
52 Soru Tümünü görüntüle
Can't get my 92 Honda Civic hatchback to run right
My 92 Civic hatchback has a 98 CRV B20 motor in it, just recently put in. But for some reason it will not run right, if you give it gas it sputters like it's misfiring or getting to much fuel or not enough and you hardly have any power. I have put everything new on it new distributor rotor button new plugs and wires new TPS sensor new throttle body, new idle air control valve, new temp sensor, new stock injectors, new fuel pump, new fuel pump regulator it don't have a gauge on it but it's new. I know there's probably more I putting you on it but I can't remember right now. But we've come to the end and want to just sell it because we cannot figure out why you can't just push the gas and take off like a real B20 is supposed to do. Is there anybody out there that can give me some more ideas or help me out anyway at all cuz I really don't want to get rid of the the car I just put too much money into it. Any ideas guys I just can't think of anything anymore. This is the car and the motor that we just put in that's not me in the picture that's my boyfriend
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Timing? Loose gas system (if pedal is cable connected to throttle)? Slipping drivetrain?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Have you checked the compression? You said it’s a different engine. Who built it? If the builder didn’t get the cam sprockets aligned correctly, it will never run right. Can you pull the valve cover and check? or check the timing with a light.
CG
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jana Walker sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 155
