Why is my screen flickering when I stream online?
Whenever i try to stream something either on Netflix, youtube, Viki my screen starts to flicker and as soon as move the cursor the screen stops flickering but starts flickering again after a couple of seconds
I am on latest version of MacOS Mojave
Video of my flickering screen: https://drive.google.com/open?id=14v8UiX...
Bu iyi bir soru mu?
2 Yorum
Check your Display settings do you have Automatically adjust brightness enabled? If you do turn it off to see if that helps.
Are you using the system off the battery or are you using the charger?
Given the systems age I would check the battery. Install this app CoconutBattery post a snapshot of the main window so we can see Adding images to an existing question a worn battery can effect the power stability which in turn effect the displays backlight (which is noticeable).
Dan tarafından
Hi, thank for the reply
i tried disabling the Automatically adjust brightness but it didn't work, i have also added a screenshot of coconut battery main window
Sparsh Sangal tarafından
