Ana içeriğe geç
The Epson Artisan 1430 is a color inkjet photo printer.
32 Soru Tümünü görüntüle
paper and ink lights both flash together
My EPSON 1430 ‘s paper and ink lights flash on and off in sync with each other and I can’t do any printing. I am not getting any on-screen error messages so not sure how to fix this error condition
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Look in Owners manual. Can find on line. It will say that this means the ink pads are full and the printer is at end of service life and to contact Epson. They will tell you to buy a new printer. Go to Youtube and search for “reset Artisan 1430”. You will find info on resetting lights and installing a waste ink tank. Sort of designed obsolescence I think.
Update: found service manual with details on waste ink pad replacement:https://www.4shared.com/archive/Cm2eWu2p...
Waste tank install is probably easier and better long term. than messy pad replacement.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Hi Roderick !
Research I just did.
This would be a problem with the printer's stamps:
Explanation of LED error codes available here.
There's this video that explains how to solve the anomaly.
Puan 1
Yorum Ekle
Blow out the paper feed area with a can of compressed air. This fixed mine after I was in panic mode.
There must have been dust or some small, unseen debris setting the sensor off. Hope this works for you.
Puan 1
2 Yorum:
Thin strip of paper appeared when I gave a little blast and BOOM, back in business!
tarafından
This was also my problem - just a little scrap of paper was stuck!
tarafından
Yorum Ekle
Another trick...before turning it on, open the upper paper tray (see pic), then close it after printer starts up. This seems to stop the 2 light blinking problem. I don't know why.
This has been working for me for 2 years
Puan 1
2 Yorum:
This fixed it. Presto!
tarafından
fixed for me too... ta ta
tarafından
Yorum Ekle
Yanıtını ekle
Roderick Salter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 73
Son 30 gün: 338
Her zaman: 10,465
