Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
275 Soru Tümünü görüntüle
F40 code flashing on Kenmore elite oasis
My kenmore dryer started flashing F40. I researched the issue and was led to checking the m2 connector(which has a reading of 56.9 ohms) and checking both the thermal fuse and thermistor(both have been replaced) but nothing has fixed the problem..what now?
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Nintendo Switch Setleri
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Cevap
Filtre ölçütü:
Looks like you have researched the issue. So it’s a wiring and/or contact issue. After you have gone over the wiring with a multimeter to check for continuity, I would start looking for burned areas on the control boards and/or cold solder joints.
Does it run at all? Does it cut off after a short duration period. What is your model number?
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Shane Letzring sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 19
Her zaman: 199
