Ana içeriğe geç
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
Can I use S8+ battery on S8?
Hi, I have an s8, and everything is awesome about it except the battery. I use it in HD+ 720p and even then i need to charge the %#*@ thing TWICE a day! i dont even talk about 1080p and 1440p. So i planned something wild to do. Can i get a galaxy S8+ battery, and put it to S8? would it fit? and more importantly what other samsung batteries are same size as S8’s but bigger capacity. and is it safe? can the phone explode? Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
No, it would not fit, as the battery is physically bigger, hence the extra capacity.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Technically you can. Nothing is going to stop you from installing a battery by taping it on to the back of the phone with a little bit of an air gap in the middle of it. This is how I charge my Galaxy S9 plus. I take my dad's phone for a minute and then charge up and then anchor to a charger for the entire day because my temperature sensor got screwed. I have noticed that over time the battery may swell if done in reverse. These batteries are older than modern phone batteries so they have no idea how many milliamp hours they hold only the phone does so if you have a 3500 milliamp battery and you want to benefit from the extra battery life you will have to charge it in a plus series phone every day and then take it out and put it into your Galaxy non plus model. At that point I would question why not just use the plus edition of the phone? You would only be able to charge it to 3000 milliamp hours instead of its fully rated capacity on the non plus variant alone, but if you're drawing the same load you would have drawn on the smaller battery the larger area of the larger battery will definitely help you maintain longer battery life to some extent at least. It's possible but largely not worth it aside from a couple of bursty loads on the battery like camera Flash or a sudden hard work load.
Puan 1
Yorum Ekle
its does fit, what im worried its about functioning, if the voltages are the same it should work no problem
Puan 0
1 Yorum:
if u dont trust me i can prove it
tarafından
Yorum Ekle
Yanıtını ekle
Univ Ersal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 35
Her zaman: 2,147
