Ana içeriğe geç
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Soru Tümünü görüntüle
Location of Apple SSD drive on iMac 2011 27" discovered
The custom configured iMac with an SSD drive hides the drive in a different place than it traditionally would be placed.
To find the Apple SSD drive check underneath the CD/DVD drive.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The Apple installed 2.5” SSD is mounted on the studs under the optical drive
Bu yanıt yardımcı oldu mu?
Puan 4
10 Yorum:
I wish I had this answer the other day before I followed various notes online and finally began digging below the Logic Board. I eventually found it the other day.
Finally right there under the Optical drive as you’ve wonderfully photographed it. Thank you for posting the photo for others, and potentially myself if I have a long day!
tarafından
@danj have one of these on the bench that I bought. Am working on the GPU but ordered the cable for a 2.5" SSD. iMac Intel 27" (Mid 2011) Dual Hard Drive Kit / Upgrade Parts Only
My thinking was to just keep the old hard drive, thus I don't have to buy an OWC thermal sensor for $50 (maybe do a fusion drive setup).
Can I retain the optical AND add an SSD?
tarafından
@mayer - Yes! There is a third SATA port on the logic board. The guide will aim you to the spare port Installing iMac Intel 27" EMC 2429 Dual Drive Kit (HDD or SSD)
tarafından
@danj Thanks, just got the cable in today. Do you know about this GPU replacement. I could not get the seller to respond to my email about it already being flashed. Seems like a much better alternative than putting an expensive Apple one in again that is likely to fail.
tarafından
@mayer What GPU replacement??
I use these TheBookYard - GPU's (exchanged)
tarafından
5 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Wizdom On Wheels sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 644
