Where does small black plastic fuse holder on the fuser assembly go
I had to take apart the fuser unit on my LaserJet Pro M477 to remove a bad paper jam. In doing so a small 1” black piece of plastic fell out containing what appears to be a fuse (looks a little like a thick SD card). I can’t figure out where it goes. I dont see anything that the contacts on the fuse cartridge would connect to.
Any help (or a picture) on where this goes would be appreciated.
Below is a picture of the part. I believe the blue component inside it is a fuse.
Aprox dimensions are 1” x .75”
Bu iyi bir soru mu?
2 Yorum
Might want to add a pic to your query so that the component in question can be identified easier.
Adding images to an existing question
prop man tarafından
May I know how did you take apart the fuser unit? I think I have some paper stuck inside the printer at rear area where the fuser unit is blocking and it's impossible to reach inside with my fingers... I don't really know how to go about removing the fuser unit so I hope you can help me somehow.
msee tarafından
