Why restart when I connect the charger?
Hy i have iphone 6 and i replaced a the battery and if i connect the charger then the phone keep restarting and i cant do with it. Any idea to fix tish problem , i rested a phone .
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Sounds like you may have a defective replacement battery or something on the logic board was damaged either during the replacement or was the root cause for you needing to change the battery in the first place.
If the old battery still worked, even if with reduced capacity, I would install it to see if the problem persists. You need to eliminate some variables here and give more information on why you had to change the battery in the first place.
Bu yanıt yardımcı oldu mu?
I try with the old battery and same thing .But i try to backup the ios and i got error 9 and the phone after boot just black screen.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 38
2 Yorum
Strange one?? Just to get it correctly the phone does not restart until you plug the charger in
Am I right??
edigitcom tarafından
Yes its very strange .
Rods James tarafından
